[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
superduke forum • View topic - Blown Engine?
Blown Engine?
Re: Blown Engine?
Postby No. 47 » Mon May 11, 2015 7:19 pm
Ta - but whilst they looked the same, were they Samco/same quality?
shadowman
Re: Blown Engine?
Postby shadowman » Mon May 11, 2015 7:50 pm
Side by side they looked and felt identical. I'm no expert on silicon hoses of course but I doubt there is any real difference.
Recovering superbike addict
Re: Blown Engine?
Postby No. 47 » Tue May 12, 2015 12:32 pm
Bore is also shot, unfortunately, so looking at +£2.2k in new parts, etc............time to strip down the original engine and check condition of rear cylinder, methinks.
Re: Blown Engine?
Postby Colonel_Klinck » Tue May 12, 2015 6:24 pm
Re: Blown Engine?
Postby No. 47 » Tue May 12, 2015 7:24 pm
Aye, will strip down and inspect but assuming that it 'survived' the broken plug episode, plan is to put new valves, springs, etc into the 65K miles rear cylinder and stick it on the 20k miles motor - SDR exhaust valves £45 each, inlet valves £145 each apparently....................................
990RR
Re: Blown Engine?
Postby 990RR » Thu May 14, 2015 9:20 am
sorry to hear bro
Re: Blown Engine?
Postby ktmguy » Thu May 14, 2015 10:43 am
Re: Blown Engine?
Postby No. 47 » Thu May 14, 2015 11:01 am
Ta - have contacted Delwest direct.
bazz21
Re: Blown Engine?
Postby bazz21 » Fri May 15, 2015 9:03 am
do all the 990 have titanium valves or only the sdr
Re: Blown Engine?
Postby Colonel_Klinck » Fri May 15, 2015 2:27 pm
Re: Blown Engine?
Postby No. 47 » Fri May 15, 2015 3:23 pm
LiferLance990
Re: Blown Engine?
Postby LiferLance990 » Fri May 15, 2015 5:01 pm
Note to self, order ti valves next time I pull apart the engine.
2007 Super Duke
Akra Evo w/o baffles
Evap removed
Akra Smooth map
Battlax BT003s
Top Block Sliders
bazz21
Re: Blown Engine?
Postby bazz21 » Sat May 16, 2015 6:18 am
Re: Blown Engine?
Postby No. 47 » Sat May 16, 2015 11:25 am
Can't find valve head, though, so assuming blown out of exhaust port.
bazz21
Re: Blown Engine?
Postby bazz21 » Sat May 16, 2015 11:48 am
my word that did do a lot damage ,wheres the spring from , id be checking con rod too for straightness , i feel for u man , cheers bazz
Re: Blown Engine?
Postby No. 47 » Sat May 16, 2015 12:17 pm
Valve spring.
Re: Blown Engine?
Postby Aphex » Sat May 16, 2015 4:28 pm
What do you think caused it?
Re: Blown Engine?
Postby No. 47 » Sat May 16, 2015 4:33 pm
Valve stem failure probably.
bruders8146
Re: Blown Engine?
Postby bruders8146 » Sat May 16, 2015 7:21 pm
Holy sugar! That quite something!
So what's the plan?
Re: Blown Engine?
Postby Motogoon » Sat May 16, 2015 8:09 pm
How many miles had those valves done?
Re: Blown Engine?
Postby No. 47 » Sun May 17, 2015 8:21 am
Re: Blown Engine?
Postby No. 47 » Sun May 17, 2015 8:22 am
Re: Blown Engine?
Postby ktmguy » Sun May 17, 2015 9:56 am
Ay caramba, that's pretty bad!
Not usual to let go that way!
Re: Blown Engine?
Postby No. 47 » Mon May 25, 2015 8:57 am
Bent con rod so complete strip down underway...............................
Re: Blown Engine?
Postby Colonel_Klinck » Mon May 25, 2015 10:43 am
:cry: :cry: :cry:
